felpro oil pan seal
Maybe a dumb question but does the felpro oil pan seal from auto parts stores come with both front and rear seals? Just wondering because I know Ford lists them as seperate part #'s.
Anyone have the ford part number for the oil pickup tube gasket that's obsolete?
<small>[ October 30, 2002, 02:46 PM: Message edited by: luigisho ]</small>
The Fel-Pro OS30636R set comes with two rubber end seals and two tubes of black, oil resistent silicone for the sides. You can get it at AutoZone for $16.99.
<small>[ February 01, 2003, 09:20 PM: Message edited by: sdpatt ]</small>
Yamaha V6
SHO Enthusiast
Rhode Island
There is a Fel-Pro set that comes with the front oil pan seal, the front crank seal, the oil pump to block & oil pump pickup tube gasket, for $17 from Autozone (www.autozone.com). I found it last month & posted it here. P/N is TCS45871. It's mis-labeled as a "timing cover gasket set".
This one does NOT come with the rear oil pan gasket, nor any silicone / RTV.
Jesse
ohio
the reason i keep flip flopping is cause the spark plugs and wires work, it sputters sickly and it only sputtered when i messed with emergency shut off. The nois is comming from the side where the belts are, what are the numbers for on that plastic peice buy the belt? If a fuel pump was bad would it still start? where can i get a tool to check my pressure. Give me some tips cant get codes for a week but what should i be looking for? No engine light comes on when started. Plz help me out sorry bout my unclearness
