failed emissions
red89mtx
Guest
kenosha area wi
well did my test today i got this for results
HC 1.3217 limit is 0.8000 fail
co 14.4810 limit is 15.0000 pass
nox 2.4775 limit is 2.0000 fail
gas cap pass i unplugged the cel light for test im thinking o2's to start with.
i tried doing koeo and koer and cant make since of it i did it per shotimes printed it all out any ideas?
ALSO I am paying shotime2511 tonight got check in hand as soon as dad gets home i can do it
thx for help
Force4
Guest
Wisconsin
well numbers are close so it cant be to bad, o2 sensors might need cleaning or to be replaced.
Did you warm the car up before you went? always make sure the motor is running warm and the cats are heated.
Buy emissions for dummies (some random crap that pathetically worked for me).
Check plugs/wires for misses ect.
red89mtx
Guest
kenosha area wi
it was just renewed friday. its no biggie aneway just going to change the o2's and do the decarbon procedure on shotimes then go try again
red89mtx
Guest
kenosha area wi
i did just renew it friday and the test was done today so i got the next 30 days or its tags suspended
Sooper Dave
It's SHO Tyme!!
Oconomowoc, WI
I had a NoX failure on my Collora in January. Info gathering lead me to think cats and/or EGR. So I go to the local parts store and the guy said tune it up and dump two bottles of Heat in the tank right before you test it. Get it hot and it will pass. Sure thing, she passed no problem.
Just a thought. I hate emissions testing.....
