Express Down Modules
alfitz
Grand Island, NE, USA
I just finished taking the express module that controls the passenger door,
out of the driver's door. Instead I installed it in the passenger door and now
both the driver and passenger have the express down feature.
That worked so well, I installed two more in the back doors with the same
result. I'm thinking of installing 4 more for the express up feature. I may
even install a master switch to control all windows, up or down, with a single
button.
But first, I will install one in the moon roof console.
Porkchop
The Black Sheep
Virginia
Al, are you on an "Express Module" binge now???
Good luck with all that, let us know how it goes
SHOTerror
Orange County, CA
Is it pretty easy to do? Are you going to come out with an adapter that will just loop right into the switch so no wiring is necessery?
shojuan
sunny San Juan Bautista,
I need express open and close for my sunroof. What happens if you get your fingers stuff through the opening when you hit express close? eek!
SHODOGG
Crowd Control
SHOCAGO
Where can I get a couple of these express modules so I can do the express down feature on all 4 of my windows?
DJ SHO
NY
SHODOG220:
Junkyard is your best bet. If there's a "u-pull-it" yard, even better. Usually cheaper there because u do all the dirty work. I jsut picked up four modules the other day for a total of 5 bucks.
nc89sho
S13 Sellout
Clemmons NC
can someone post a pic of one of these and a few cars they would have been in? i've got a U-pull-it down the road i could get them from
DJ SHO
NY
Don't have a pic of one, but it's a little rectangular black box (maybe 2" X 3" X 1") with a flat 5-wire connector on one end of it.
You should be able to get one from most 92ish and up Fords, Mercury's, & Lincolns. Just check the car's window switches to see if there's an "auto" button for the driver's door window, then tear the door apart. The box is located in the driver's door. Make sure to get the connector too and leave a good 6 inches of wire.
