estimated time for upper 60k?
wally05
Indiana
About how long will it take to do a full upper 100k? I'm just wondering b/c I no longer have a heated garage to do this work in and I will be forced to do it underneath a carport cover. It is cold out. I have 106k miles on the car and I will not be driving it much until spring and summer. Should I just wait? I have to seal up the rocker rust with my por-15 kit at least over Christmas break.
Korey
SHOck
Louisville, Ky. USA
Korey
Wait until the warmth cometh.
lithy
Knoxville, TN
Well I did mine in 6 hours and that is including making a stupid mistake and having to spend the last two hours struggling to get the rear intake plenum bracket since I didn't start it before putting the intake manifold on.
So take that out and its 4 hours, I'm no novice to a wrench but it was the most in depth work I'd ever done on my own car.
I'd say suit up and do it in a few sessions, but I'm stubborn and don't let the cold stop me ;)
You should wait. Here are a few of the prerequisites from my valve gapping procedure. Not only will the cold numb your fingers, it will likely result in a non-optimal setting of the gaps.
1. The engine should be at the ambient temperature that the engine operates in during its use. Performing the gap adjustment with the engine temperature in the range of 40 F to 90 F should be acceptable.
2. The procedure should be performed in a closed environment such as a garage if possible. Blowing dust in an outdoor setting could be damaging to the engine when it is restarted.
3. A clean lay-down area should be available to store the parts as they are removed from the engine. Paper or cloth towels on the floor will be adequate for this purpose.
wally05
Indiana
Thanks for the replies, guys. I didn't know about the prerequisites. I have done engine procedures under carport covers before (where I would be doing it, probably). I am organized about doing that kind of work. :).
Thanks again.
tominos
oregon
how long does it take to do a front 60k, and a top 60k? seperate times, if you could please. i'm trying to get an idea of how much time is needed for the 60k as it needs to be done on my 95 soon.
front 60k time?
top 60k time?
if you did the front and top 60k at the same time, time? =)
yzstud
< my kawi
Minnesnowta
front 60k time?
top 60k time?
this topic has been covered many times before, use the search button
if you choose not to, please do not revive old threads, start your own
