Engine Turns Over but doesn't Fire
joshy1410
Wisconsin
I have a 95 ATX.
Was runniog fine, parked it and when i went to start it agaign it would just turn over.
Things i know:
I have Fuel
No spark
I pulled codes and got 3: 212, 214, 634.
I have some information as to what the codes are but i was wondering if i could have them in lamens terms.
the 634 code stumps me becase i have an automatic car and that code pertains to a stick
any suggestion to what it is.
any help would greatly be appreciated.
thanks in advance,
JOSH
Kens1992mtxSHO
The Commonwealth
212 (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
214 (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
634 (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault Electronic shift transmission - Manual Lever Position (MLP) sensor out of range in PARK - Transmissions
Check your DIS and your grounds.
634 does pertain to your car (ATX) also.
Distributoless Ignition System module
The gray colored electronic module on the passenger side of the intake manifold. There are electrical connectors at the front and rear of the module. If this module is not well grounded or one of two of the connectors is not secured, you can get the 211, 211 and 214 codes. The ground path is through the braided copper wire attached to the upper bolt on the passenger side, rear intake manifold bracket, then through the mounting bracket bolts that secure the intake balance tube (that the DIS is bolted to) to the intake.
