engine swap
ncfirefighter
north carolina
i know this question might have been answered in the past. but i am new so bare with me. i bought this 96 sho busted cam. busted pocket too not enough to fix either :lol: anyways i have a wrecked 98 se 24 valve durtec. and i am planning a engine swap and changing pcm as well. i was wondering if anyone has done this before or heard of it being done ? and if so what all has to be changed? and also can a gen 2 intake fit the newer 24v engines? i think if i can find enough mods i can get the extra 30 hp to match the v8 model. :confused:
Mr Anonymous
Tire Wall
You might have to pull out both dashes and swap the dash harnesses as well to make it work. The V6 SHO intake will not fit a Duratec motor.
Sagabu
~V-8 SHO Resurector~
Maroon , Ohio
Pull the head , check for a fubard piston . If the pistons are just dimpled w/smiley faces , check the valve seats , replace the bent valves , head bolts and gaskets , and put welded cams in it . Much easier/cheaper to do than a conversion .
