Engine stalled
WTFvolvo
Broken sho
Kissimmee, Florida
I was driving somewhat spiritedly, and after i shifted to second when I got back on the gas it sputtered and backfired a lot then died. The engine turns over, but just sputters and hiccups. What could the problem be? I know I need to new power relay module or whatever.
WTFvolvo
Broken sho
Kissimmee, Florida
Bump...
I not with the car right now so I cant look at it, but could it be the fuel pump relay in the trunk?
When it turns over, it sounds like the pistons are rubbing metal to metal with the cylinder walls sometimes, but the car has oil.
Kens1992mtxSHO
The Commonwealth
Sorry I missed this post before. So what ended up being the problem?
AREA 91
PA SHO SHOP
Area 91
What was the problem?
1. bad fuel pump
2. bad ccrm box
3. timing belt jumped
4. dis module not grounded properly
WTFvolvo
Broken sho
Kissimmee, Florida
I was getting too much fuel at WOT. My engine flooded, and after constant cranking, the excess fuel burned off and it finally started.
93rev2sev
Hockeytown
I'm sorry I didn't see this post earlier, too.
I'll be watching more carefully for your next one (you know...the one that explains that you still have the problem)
