Engine shuts down after 1-10 miles of driving?
CWhalenSHO
Florida
New to the boards here, not new to SHO's. My problem is that after driving for 1-10 miles the engine simply shuts down. (Rather interesting situation when cruising down the highway)
After an hour or two, it'll fire right back up....but then only for a few miles and does this again.
Other than this, the car is running perfectly.
What could be causing this? Thanks in advance for any help.
93 MTX
revhardSHO
Seattle, WA
It could very well be the crank position sensor that is malfunctioning.
This sensor is an important component in the ignition system, and if its not working correctly, you will have a random stall - no start condition, because the engine is intermittently loosing spark. Do a search on CPS or crank position sensor replacement.
johndallara
Chapel Hill, NC
shut-off
I agree. Sounds like CPS symptoms. I would run the codes first.
Time for a 60K service.
http://www.shophoenixproject.com
You can pay someone to do this, or with your own tools and a little time you cn do it yourself. Used above website myself and did it in my garage, though it took a while first time.
You would need the front 60K service for the CPS. Main parts to replace are drive belts, timing belt and front main seal. Cam seals if they are leaking, otherwise can skip (they are a pain). Then the CPS itself.
Hardest parts of this service are loosening the crank bolt, exposing the timing belt (lots of time), getting the various pulleys off (esp. the crank pulley and sometimes the crank sprocket). After that, CPS gets put it behind the crank sprocket, which is part of the timing belt setup.
Getting the timing marks right is not hard. Use the "straw method" to verify TDC.
http://home.mindspring.com/~johndallara/sho/id16.html
http://home.mindspring.com/~johndallara/sho/id13.html
Rest is not bad.:salute:
Best of luck.
JD
CWhalenSHO
Florida
Thanks for all your help guys. I'll hopefully be able to post some pics so you can check it out.
I'm located in the south. Jacksonville, Florida. Anybody from this forum in my neck of the country?
johndallara
Chapel Hill, NC
SHO issues
doug lewis (FPS) in Atlanta would be a good option if you need an experienced SHO mechanic.
they are on the web and in the yellow pages.
best of luck,
JD
Bizzy
If you get in touch with Chris (SuperchargedSHOguy) here on the forum, he should be able to point you in the right direction on who is in your area that could possibly help. There are quite a few people down there but I've lost track of who does work and who doesn't.
1993BlackSHO
Arlington, TX
93 MTX
I had these exact symptoms on a car once years ago, and it turned out to be a really clogged fuel filter. The fuel would bleed through enough while the car was sitting, but after that fuel was used up. it would starve the engine.
Bizzy
I could see this happening, thus why running the codes should precede any repairs. A failing or faulty CPS should leave a code in the computer.
kornsho
Fort Worth, TX
I had this same thing happen, and it did NOT throw codes. The water pump had a slow leak that leaked onto the CPS. Car dies - water dries - car starts. Good luck!
Korn
crystizel
