Crazy Phreak
Hi guys
. Just recently I got my hands on a 1989 SHO 5 speed. Well, the guy who sold me it neglected to mention the heat problem after extended driving (1 hr. + ). I was wondering, since I am not terribly gifted in diagnosing cars, if I could find some help here. I'll start by describing what goes on. After around 1 hour or so of driving in fairly warm temperatures (70 degrees) the car will stall on me. Once it stalls it takes a good 15 min. to be able to start it again and it stay running. What I have been doing to make it drivable is turning on the heater and rolling down the windows to pull some heat from the engine. If anyone can recommend a solution I would greatly appreciate it. I also ran the key codes and I come up with 14 , 49 , 83, and 87 for the Key On Engine Off Test. When I turn the Engine on I get code 21 (Engine Coolant Temperature (ECT) sensor out of range) which I am imagining this is my main problem
. Is there a cheap solution to fixing this?
