I just got an engine off of eBay, so now I have it sitting out of the car. I don't have large sums of money (and I don't want to **** the fiancee off too much
. This is what I have on the list right now. My main goals are: 1. to replace the 60K and other important items before I install the engine, and 2. to replace wear parts in generally.
This is what I have on the list right now:
Timing Belt
89-93 Alternator/AC belt JK6-450
Water pump PW-272
O2 Sensor DY-606
Upper Rad hose KM-3084
Lower Rad hose KM-3086
Thermostat RT 1112
Gauge Temperature Sending Unit SW 2328
Timing chains
Upper gasket set LESS head gaskets, for 60K for ATX or MTX
Front crank seal
Crank position sensor DY-910
Cam position sensor DU-47
Tranny refresh, seals and blocking rings
Am I missing anything?
Timing Belt
Water pump PW-272
O2 Sensor DY-606
Thermostat RT 1112
Timing chains
Front crank seal
