engine makes snaping poping noise fron 4-6k
shoclown
shoclown
sacramento ca
okay i have replacaed the intake runners with ported ones and installed BBB and now the engine makes a lot of noise above 4k? Sounds like a missfire but all plugs wires etc is new fresh complete 60k all is stock now except ported runners and bbb, ( also have pcv catch can installed)
nothingtoseehere
I think your first issues is new plug wires on a V8 SHO ..... there are no plug wires.
93rev2sev
Hockeytown
he's talking about 60k's BBB's and 4000RPM....
He's gotta be talkin about a 1/2gen.
SHObill
'The Collector'
Rochester MI-48307Detroit
You made previous posts about 'her' feeling slower after BBB's & acid runners.
http://www.shoforum.com/showthread.php?t=96886
now you say you have noise after 4K RPM.
I suggested completely replacing the intake for a stock one before.
NOW suggest it even more!!
Do the BBB's have a new larger plate in them that seals well & do they open/close with no binding? Did you locktite all the plate screws?
Stock plates in BBB's will not 'feel' the same@4K. Loose screws on the plates will make noise untill they get sucked in to the combustion chamber & take out a valve & bind up a piston & then you will have some noise!
--Oh- mods please move this---!
DaSho97
Former Owner
Mass
im reading it and thinking 60k?wtf? wrong section my friend.
