FOMOCOTOSHO
I eat Rice.
Ok everyone, I need some help asap..
My '95 ATX started knocking a couple days ago and I had it checked out. I talked to Kurt @ NE SHO and had 2 different guys locally listen to it and they told me it was the rod bearings.
My q is should I also do the main bearings too? Kurt told me just the rod bearings is all I need.
Another q is how do I do this without pulling the motor? Kurt said you can do it but is there a special way of doing this? How can you replacing bearings with the crankshaft & everything still in? Any special tricks or trips?
Last q, if I do the main bearings, where can I get the thrust washers? Rock Auto has all the bearings & seals I need, but the description on the main bearings says "requires thrust washers not included in set" and they don't sell the thrust washers. Where should I get these? Or is there somewhere else I can all the parts at once?
Please help?!? I sold my other car now so this is all I got.
