engine electronics component ques
lobo2112
northern NY
i kno this is probably the wrong forum but more ppl seem to come here than the electronics section if you've already read my post there you can ignore this.. thanks :thumb:
okay heres the deal, i have a 95 3.0 sho and needed to replace the ccrm and ecu, i got both out of a 90 sho... can i just plug them in or do i have to cut & splice the wires in the harness. i checked my wire whip for the ccrm against the wiring diagram for the 90 and the colors dont match up, also from what i can see on the 95 diagram there seems to be connection differences... is this just because of different options packages or am i in for a long night of wire tracing and splitting?
CheckerSHO
Ford Employee
Acworth, GA
The ECU should plug up and work but that CCRM probably isn't going to work. The 90 does not have a dual speed cooling fan and since that is controlled by the CCRM I don't think you will have proper fan control.
