I have a 92 MTX and sometimes while driving normal speed or sitting at a stoplight the car will just shut off. When I go to try and start it back up it turns over but will not fire up. I have to wait like 30 minutes before it starts again and sometimes after it starts it will die after a few minutes but most of the time it wont.
Other than that the car runs beautifully but im tired of having to push this thing out of the traffic and wait in parking lots until it decides to start.
Was thinking maybe its a bad crank sensor but i noticed that the battery light comes on after every start and goes off after the rpms go past 2000. Just got my charging system checked and it is at 11.x volts as opposed to the 13.x it should be at. Could this be a bad alternator also?
Also, how do you pull codes on these cars?
Also if the crank sensor is bad from the water pump leaking onto it, if you replace with a new sensor, wont that one also go bad shortly after from the water pump dripping onto the new one? Is there some way to cover it up so it wont get wet again?
