Engine Codes
The SHO
How in the **** do you get the grey plug out of the computer code test cover. The black one slid right out but i cant figure out how to get the grey one out.
The SHO
Here's what we're got
KOEO:
327 - EGR feedback signal is/was low - EVR or PFE
176 - Oxygen sensor not switching - system is or was lean Left or Front HO22SSS - Fuel control
KOER:
116 - Engine Coolant (ECT) sensor out of range - ECT
538 - System did not receive "goose" test
536 - Brake On Off open or shorted to ground - BOO
521 - Wheel not turned during test or PSP problem - PSP
632 - E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
A little help with the meanings of these, I'm a rookie. Thanks gurus.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
538,536,521 You didnt complete the test properly.
Might need O2 sensors.
I would unplug the battery and turn on your headlights and pump the brakes. This will erase the computer. Then redo the test again and properly follow the procedure for the KOER test.
