engine cleaning???
NotoriusCSR
colorado springs, colorad
are there any shops that are able to clean the engine bay using some process or another? i tried to hand clean mine on sunday but didnt get too far. just about everything is dirty and decided it didnt want to come off. i was wondering if detail shops or something have a way to clean engine bays to almost-new? i know about the dc-2? detail kit but really dont think that it will help too much untill after i get a major cleaning done. but i may be wrong, if uve used it and say it works miracles ill try it.
94shoboy
south shore, mass, usa
most detail shops can get it like it just came off the lot. call around and you should be able to find a place close to do it. i don't know how much it will cost you though.
SHOspeed93
Mc Henry, IL,
Im getting mine cleaned at work....One of the many benifits to working at a dealership..
Tony Dvorzsak
93 Green ATX
DYNO results 197 torque and 175 hp at the wheels
246 torque and 218 hp at the crank
Eibach Springs, Strut Tower Braces
2 Chambered 40 Series Flowmasters
K&N Air Filter, Boxless
and Five-speed shift **** conversion
And a new trans, Indilgo Gauges
SHOcago Member
AIM: SHOspd93
waddsn1060
Prospect Hts, IL, 60070
Damn you Dvorzsak!!! And its not the DC-2 its CD-2 Engine detailing kit. Its a 2 part deal. First you spray the engine down with the engine degreaser they give you. Rinse it off then put the detailer on and your set! John (SHO2NV) uses it and his looks really good. There are 2 places around here that will do it, $85 and $100 each though.
91 BLACK MTX
Some mods, nothing worth mentioning.
0-60=6.32
1/[email protected]
Brad's Memorable Quote from The Simpsons:
Ralph-"Mr. Simpson, these tar fumes are making me dizzy."
Homer-(nonchalantly)"Yeah they'll do that."
CMurderSHO
pittsburgh,pa usa
cleaning the engine is not hard it is just time consuming. But once you have it clean just like the outside and inside the car it just gets easier each time after. Just takes a little elbow grease the first time if its never been done.
96 silver frost
18" asa js5 wheels
245/40/18 kumho esctas
bullet turbos 3 1/2" tips
open K&N filter
powerslot slotted rotors
asp underdrives
triple guauge pod oil,volt,water
http://cmurdersho.tripod.com
SnoSho
Circle Pines, MN, USA
Side note:
COVER YOUR CPS! Water from a leaking pump is what usually kills them but you can **** it yourself with a water hose
Tim M.
