Engiine Problems Gen. 1
89SHO X2
Wa
Idles good, accellerates good till the secondaries kick in then it bogs down some and hesitates and gradually accelerates but not like it should. when cold it idles fine but bogs way down on acceleration and has no power and will not accelerate if you step on the gas. it ran fine a while ago. this has been an on going problem. goes away and comes back. sometimes also when i go into the store and come back out it will run rough and hiting the gas it will the idlle goes up and down for a few seconds like a missfire then goes normal.:munch:
93rev2sev
Hockeytown
Please indicate maintenance history. If you have not performed any, start with plugs and wires.
Misfires and bogging are usually maintenance related...
plugs, wires, dirty sensors, fuel filter, poor grounds, etc..
shobote
Naperville, IL
Could be a number of things; how many miles and what has been done; e.g., has full 60k been done anytime recently ? might be fuel pump dying, clogged fuel filter, dirty MAF, oil / water in plug wells etc..
TYSHO
Earth
Make sure your grounds are good, check your fuel pressure, make sure your secondaries are opening, and check for vacuum leaks...the easy, free things.
yamahaSHO
E85 whore
Arkansas
When has the fuel pump been replaced last?
More information would a big help.
89SHO X2
Wa
Fuel press. is 30-38. ran a lot of injector cleaner resently. have filter but have not repllaced yet. owned the car for a year now. past hist. not known. heads look and cams look great and very clean. timing belt not checked yet but soon. tuned it up recently.
89SHO X2
Wa
TYSHO: Thanks for the info. I have already done all of those recently. need to replace the cables though. re-routed the ground recently around the back of the engine to the drivers shock tower. Also checked the secondaryies and engages when the trhottle is moved. No oil or water in the spark plug tubes, sealed heads recently.
yamahaSHO
E85 whore
Arkansas
Hmmm... Are there any tapping noises coming from the front crank dampener?
89SHO X2
Wa
will do. I have another car that I am installing a clutch on right now.
89SHO X2
Wa
Thanks all. I diss. the maf and it ran fine so i am going to replace it.
93rev2sev
Hockeytown
First, try cleaning it. If you insist on replacing it before trying to clean it...please PM me..
I'd love to have it.
89SHO X2
Wa
I had the mesh screen out of the maf and put it back in and it runs real good now
bmytych
