ELECTRIC cutting out on start
Warren
New York, N.Y.
Sorri I accidentally posted this in the performancs upgrades thread.heres the issue
So I had an issue for a while where the car wouldnt start up occasionally, you would hear it start to start for a split second and then nothing, try again and nothing at all.. so I would have to hit the starter with my flashlight and the car would start fine...
Now I try to start my car and all the electric just cuts off. I have to wiggle the wires at the battery terminal to restore power, try to start it again, **** everything shuts off. I took the cables off of the battery to find my negative battery cable completly corroded with white stuff. I chopped off the first inch and a half and removed some of the rubber insulater and its corroded all the way down. What would cause this to happen? If I want to replace my negative cable, where is the other end connected to?
frosho
WOLFMAN
Tyngsboro, MA
It's normal for them to get corroded with age. The negative cable runs from the (-) battery post to the engine ground (starter bolt). I think the PCM ground tees in at the battery post.
Mike Gallion
Marseilles, IL.
X3 for cables!!
Check them over really well, I had one that went bad smack dab in the middle of the cable, right down by the bottom of the radiator!
crystizel
