morebhp
Here's why I ask: My first SHO was a 90. I never had any drivability or power loss problems with the engine. It started and ran strong instantly even cold.
I've also had two 95 MTXs, one of which I still own. Both of them have always stumbled for about 5 minutes after a cold start between 2K and 5K at part throttle. The blue one (which I sold) would warm up and be fine and run really strong at all RPMs. My white one (which I still have) never seems to fully recover. It always has this jerky little cough between 2-4K. Some days its worse than others but always there.
Does anyone elses '93-'95 MTX have this same behavior after a cold start?? What the heck is it??
I seem to recall reading that in '92 or '93 there was a change to a two speed fuel pump. Could that be it? Or perhaps some additional emissions crap?? I truly believe something they changed weakened realiability/drivability a little. Even my dad's old beater '91 SHO (155K) doesn't do this. Grrr!!
It's not the plugs or wires. They've been replaced twice with OEM stuff. Didn't help.
I've also replaced...
-Coilpack
-HEGOs
-MAF
-TPS
-CPS
-IAC
-ECT (coolant temp sensor)
-Tested ACT (air charge temp sensor)
-The manifold very is clean.
-I've checked vacuum hoses.
-I have no codes.
I checked my butterflies tonight. They close nice and tight and won't open even with the engine off until I take out the key. Then they release.
I'm open to any suggestions or wild guesses. I'm stumped. ...and frustrated.
-Coilpack
-HEGOs
-MAF
-TPS
-CPS
-IAC
-I have no codes.
