eatc trouble codes
mef18352
pennsylvania
I just performed the self test on the eatc and got a trouble code of 02 am i missing a number because I can't find out what it means. I did it because my heater isn't blowing hot air. the fan goes but the air comes out cool, i checked coolant levels bled out the air and both lines to the heater core are hot. Is it the blend actuator? and how do or can you fix? and is there a way that is foolproof to make sure that is what it is?
mef18352
pennsylvania
nevermind guys I got to searching and found what I believe was the problem, a while back my bcm went and i jumped wires to get the fan going and must have shorted the bda causing the fuse (no17) to blow, i replaced it and now it seems to be working fine. thank you all again
Racer X
SHO Pilot, Retired
Connecticut
Code 02 is a BDA failure. In the beginning, it's an intermittant failure that will sometimes correct itself with a decent sized bump or pothole. I'm dealing with this gremlin right now. :(
projectSHO89
SHOless In St L
Failure of the supply voltage to the BDA will also cause a "02" fault. He pointed out the fuse was blown and that replacing the fuse restored operation.
Steve
