Since you have an error code, it can't be a fuse. Since it's an automatic system, there's no resistor pack..
NOTE: If the interior temp of the car was below 50F or the engine was not fully warmed up, the EATC self-test results may be invalid. Be certain that these prerequites are met and the self-test fails before doing the following.
Open the glovebox fully (squeeze tabs). Remove the sensor from its bracket (behind the SHO logo). Disconnect the electrical connector.
Measure the sensor's resistance.
Depending on the inside temp, its resistance should be as follows:
Sensor Resistance Table
APPROXIMATE TEMPERATURE..............SENSOR RESISTANCE
10C to 20C (50F to 68F)....................37K to 58K ohms
20C to 30C (68F to 86F)....................24K to 37K ohms
30C to 40C (86F to 104F)..................16K to 24K ohms
If the resistance is incorrect, replace the sensor.
If the resistance is correct, then there is either a wiring fault (open or short circuit) or the EATC is defective
Steve
