E sensor install..
mybigsho
new york
So i finally installed my sensor and what an awesome piece of equipment.. I'm just not to happy with
install.. I wanted to use the original line with two strait connectors but it was to tight so i used two 90
degree connectors.. Lets see some pics of other peoples installs..
Thanks Scott
mybigsho
new york
IMG 20200418 170240629 IMG 20200418 170240629
skyshadow07
Oklahoma
What brand is the sensor? Does it feed data to a Bluetooth connection or through OBD?
Zpak
Es Aich Oh!
The region, Indiana
I just got a Bluetooth Fuel It sensor. It just sends the readings to the fuel it phone app. Haven’t installed it yet though. I’m waiting on a few more pieces of the puzzle first.
Zpak
Es Aich Oh!
The region, Indiana
Thanks Scott
What wire did you tap into for the power?
ridered74
Was your fuel line short or something? Yours looks like it's sitting on the motor.
mybigsho
new york
I got the fuel it bluetooth for the android and sensor from a gm vender i deal with.. The fuel hose and sensor where
to long so i had to re route to shorten with the 90's.. Got some loom and wired up under the cowl into the fuse box
with a piggy back mini fuse..
Zpak
Es Aich Oh!
The region, Indiana
Do you recall which fuse number you tapped into. I thought I remembered seeing somewhere 36 was a good one for keyed on power.
ridered74
Keep forgetting to check the #, but it didn't have a fuse to start with. I used a multimeter to find one that only had power when in run position, then installed the fuse with the wire tapped into it. It was towards the middle tho.
Zpak
Es Aich Oh!
The region, Indiana
Cool, thanks.
ridered74
Here is where I tapped in.
Zpak
Es Aich Oh!
The region, Indiana
Thanks guys. I’m super excited to get this all together. Still waiting for my special package from XDI to arrive.
Stupid overbearing Michigan shutdown!
