Driving and shut off no start
smokin joe
Milwaukee WI
Well I was driving along and it was like someone flipped the key off. Did some work on it last night and it sat all day but no start after work(i know alot of times if its the crank sensor it will fire eventually) I have spark and pressure at the fuel rail(pump does prime), switched the DIS, Coil packs, Cam Position sensor, checked the timing belt and thats fine. Im not sure If it would be the crank position sensor because it has spark and the tach moves when cranking. Im stumped on this one because it has spark and fuel just wont fire. Im going to go swap out the computer and see if that does anything. PLEASE HELP!!! Thanks Joe
smokin joe
Milwaukee WI
Well after more digging around its the timing belt so it looks like a long day or two for me
'94SHO
Towley rules!!
R.I.
You are lucky it didn't start!! this would have melted your engine down in no time.. (Friend did this, got it started, and was wondering what the sparks were coming from the exhaust... It was the rings.):oogle:
