driver side axle installation
rktmn
Well-Known Member
miami
What was I thinking?
I installed my new axles today, filled my tranny with Royal Purple, and the driver's side axle seal is leaking a drop a second.
Should have changed out my axle seal. Even though I installed it new about a year ago when I did my tranny.
New axle, new seal.
Now I got to pull that axle again.
I remember tapping the old sela out from inside the case.
I guess that now I will have to pry it out.
Any tips?
Jose
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Dont scratch the mating surface on the tranny case ;)
To remove mine, I think I remeber just grabbing the inside edge of the metal portion of the seal with fine needle-nise pliers. Then PULL.
To reinstall, I used an ABS pipe "cap" and a rubber mallot.
SASHO91
Zoom Zoom
San Antonio,TX
is there any way to tell if the seals are still good?
i just picked up my trans, with 60k on it.... ran with red line tranny fluid....
i wanted to know if there was any way to tell if they were still good?
thanks.... i know im a hijacker!!
SASHO91
Zoom Zoom
San Antonio,TX
Dam!!! i wish i had knew about that earlier.... thats the reason im in this position... pass. side axle leak.... had about half a quart in the trans.... then it went shoboom..... well the spider gear did....
thanks for the link josh!
i should have known you would have had something on file there.....
SHOMurph
Ford B@stard
Arlington, TX
Anytime axles or the tranny is replace new seals should be put in.
My axle seals are fairly new and still leak a bit.
Shoaz
Studly dood
Scottsdale, AZ
I only change 'em when they leak, but they shouldn't leak at all when they're working right.
They can be pried out, and there are raised tabs on the tranny case to help do this.
Sho-Driver
Peter Pan
The Garage.
Scratching the tranny mating surface is that big of a deal compared to gouging the rubber seal. The mating surface can be sealed up from leaking as you install. Once the rubber seal is gouged, it is done.
SHOMurph
Ford B@stard
Arlington, TX
Mine are installed right but still leak a little bit. Dunno....maybe its torque that tranny is put through.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Sure, but I dont make a habit of damaging things.
And why risk creating another source for a leak?
Do it right.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
With the way the axle seal functions, even tiny imperfections in the axles stubs themselves (where the seal rides) can cause premature or imediate leakage. I could also see imperfections in the rubber coming into play as well.
These seals provide nearly zero room for error to work right, and last long.
rktmn
Well-Known Member
miami
Any brand axle seal is good, or should I get it from a Ford dealer?
Autozone claims to have them in stock.
I do not want to this this again.
When I installed the Quaife, I changed the seals, and they never leaked.
Jose
SHOMurph
Ford B@stard
Arlington, TX
I have had three different sets of seals on my SC car trannies. Two sets have leaked.
I guessing with the amount of torque plus all the banging that happens sometime during with wheel hop/accleration that may cause the seal to become somewhat pressed or damaged.
I'm getting a solid tranny mount from HyperMike. I'm hoping that will solve alot of issues.
Sho-Driver
Peter Pan
The Garage.
Do it right.
I was not implying you scratch your surface on purpose. I stated that it is not as big of a deal as it was made out to be.
Shoaz
Studly dood
Scottsdale, AZ
It apparently helps quite a bit to put some anaerobic sealant on the ****** when replacing these. I'd never seen instructions anywhere (including the Helm) to do this, but I've had them leak when this isn't done. If folks are having trouble with the seals leaking they may try using some good anaerobic sealant (NOT RTV) when replacing the output shaft seals.
olympic
Saskatchewan, Canada
Yep, Josh @ SHOnut does this in his Quaife video. It won't stop leaks between the axle and the seal, but it'll seal up any imperfections between the ****** and tranny case.
Ishodu
This is what happend to me. Did the clutch and replaced the seals. They leaked around the ******. Had to replace them again with tranny installed. Much more of a PITA that time I used the anaerobic sealant and they haven't leaked a bit.
