driver side axle installation
rktmn
Well-Known Member
miami
I went to about 5 different auto parts before I found one that had the MTX axle seal. Tomorrow I will try to put it in.
I should have my SHO together by this weekend.
I hope.
Jose
rangerj
Brunswick, Ohio
There is a TSB (old one) that recomends that the ****** be coated with anearobic sealant before it is installed. You should also be careful when installing the axel so as not to damage the seal as you slide in the axel.
Also check the axel for any rough surface caused by corrosion and/or any burrs or nicks that could damage the seal. Lubricate the seal with grease if it does not have any on it. Then lubricate the axel with the trans fluid before sliding it in. rangerj
AREA 91
PA SHO SHOP
Area 91
I had a problem with a bad CV shaft, that was eating my driver's side seal. I replaced the seal 2 times, before changing out the shaft. It must have been the shaft the whole time! Double check like spdatt said. :thumb:
