Dome lights won’t fire automatically
JRV1631
Lake Wylie, SC
A year or so ago I purchased LED scuff plates. I also replaced all of the interior lights with LED’s. Then one time, after having the doors open for an extended amount of time upgrading the speakers, the dome lights would not fire when opening the door. But, if you get in and press any of the buttons, they light manually. I took it to the dealer and in the middle of the pinpoint test they just started working again. They told me about the resistors, I think the term was “afield” resistors? They said if it happens again, from having the doors open, to disconnect the battery for 5 minutes. So, a few days ago, it started again. I disconnected the battery for 5 minutes. Then 10 minutes. Then a half hour. They still won’t fire automatically. They were giving me grief at the time about the aftermarket LED’s. My wife swears she only left the door open, “...for a minute or two.” . Before I go back in and let them have their way with me...any suggestions? If they fire manually it can’t be a fuse. Can it? I’m at a loss. And about to take a bigger loss! But I can’t stand it when something, no matter how small, doesn’t work!
JRV1631
Lake Wylie, SC
Maybe try new lights?
Sent from my Pixel 4 XL using Tapatalk
But the only problem there is it’s all interior dome lights. Not just the new scuff plates. When I open the door, all of the lights that normally light, are dark. But when I push the switch on say the map lights, they fire right up. Same as the rear dome light, etc. makes me think it’s something in a million dollar module or something.
xFallenxCripplex
How are the door triggers have you verified that all works.
And did you happen to use forscan or a button press to turn dark car mode on?
JRV1631
Lake Wylie, SC
FORScan is out. Haven’t used that on this vehicle in over a year. I’ll check the door triggers. But I’m not optimistic because it’s unlikely all 4 failed at once. But stranger things have happened. I’d like to get a hold of the pinpoint test procedures for the dome lights.
crystizel
