Do these times sound close?
Dhanning
Carmel, IN
2013 Taurus SHO. Livernois 93 octane tune, plugs, 3 bar, KN CAI, Anthony performance trans mounts are mods.
Used GPS “race timer” ap.
Conditions - 19 degree dry
No rev launch
0-60: 4.2
1/4 mile: 12.3@107mph
Since this was an ap timed run not sure how accurate this is. Trans mounts are amazing at taking out driveline slop.
The car has not been tuned on the dyno yet. Thinking about taking it into Livernois next time I am in Detroit and see what they can do to fine tune it even more.
Interesting that the trac warning light and front collision warning came on after the run.
Restarted car and messages cleared. Anyone else experience those warning lights after hard run?
mybigsho
new york
I don't think that mph could run that low et unless your 60' was real low 1.7's.. I was running
12.7's 12.6 at 107 mph with 184 183 60fts.. The trans mounts work real well and yes you can experience traction light coming on.. Good luck and get to a local track to see what it will do..
76FoMoCo
Nampa, ID
dragy is your best bet a 4.2 0-60 with your set up no way. I looked at some of my old slips and 107 is about a 13.0 depending on your DA. 113 mph is 12.4 ish.
ridered74
Going to buy draggy! Thanks for the comparison. Race timer is s**t. No surprise, I think it was free!
I've tested a couple of the free apps, no surprise they are always off dragy by a good bit. I would guess with just a 93 tune from lms you'd probably be high 12's in decent air.
