disconnect the throttle from the throttle body..
SHO.fast
Wants Boost
Littleton, CO
okay so im removing my intake for my first time.. i have everything disconnected and all bolts removed it is ready to come out... but the only thing that is left is the throttle connected to the throttle body... is there a special way to take it off so i dont mess up the throttle position??
thanks guys
hawkeye18
Sorta cares
Norfolk, VA
Why are you trying to remove the throttle spring assembly from the TB? All you need to do is remove one 10mm ogive bolt at the little metal bracket that holds both the cruise control and throttle lines, then while you rotate the spring assembly a little with your hands (as if stepping on the throttle, but not pulling on the cable), route the cable out of the spring. The cable has a little barrel at the end of it, and that slides into a slot in the spring. It should come out sideways. If you rotate the spring, the cable will splay out and it'll be pretty obvious how to remove it.
SuperHO
Mental Patient
St. Joe, MI
i've never removed the throttle body when taking off an intake. there's enough play in the cables for it to sit comfortably out of the way on the driver's side strut tower. stop overcomplicating things.
