JLT1787
SHO-OUT
My Idle seems a little erratic. I replace the everything i could think of that would cause it...i think. I have a 93 Mtx and advance has 3 different DIS Mods and i was wondering if the $196 one is the one i want or not
Rockledge said:A new DIS module isn't going to fix a bad idle. Look elsewhere for the source of the problem.
I had an issue a few months back with a horrible idle and the car was running on 4 cylinders (2 fouled plugs). Replaced plugs, then coil...nothing. Swapped on a DIS from the parts car and she fired right up!The point is that the DIS module is either working properly or it isn't. It won't malfunction only at idle; it will be bad throughout the RPM range. The OP's concern has to do with idle only.Mike Lundeen said:I disagree!!!I had an issue a few months back with a horrible idle and the car was running on 4 cylinders (2 fouled plugs). Replaced plugs, then coil...nothing. Swapped on a DIS from the parts car and she fired right up!
Rockledge said:The point is that the DIS module is either working properly or it isn't. It won't malfunction only at idle; it will be bad throughout the RPM range. The OP's concern has to do with idle only.
Mike Lundeen said:I'd be interested to hear how the original poster's car is while driving, not just at idle...
In my case the faulty DIS had caused plugs to foul, therefore poor idle as well as drivability. If his car drives fine then I'm stumped.![]()
