Dis module or ignition dont know
beboshopower
Florida
muy sho make a weir when startin it like if it ws the starter but is not...i unplug the ignition sensor an plug it bak an it did it could it be that....
VADERSHO
C-DAWG
Tulsa,Oklahoma
me sry bt tis wuz hrd ta red....lol just givin u crap
Its makeing a weird noise? Is the noise when you turn the key on? or when you actually start it? It could be the DIS go to the junk yard get one cheap and try it, then go from there.
Bizzy
Codes? You might want to try and elaborate a bit more on what exactly the problem is. I'm sorry, but I can't make heads nor tails of what you said is wrong.
Moving to the proper section.
beboshopower
Florida
when i turn the key an start to start it an i dont know if is the same problem i have wit the cps because ma car be shuttin down whilw im drivin...thats why i wanna make sure whats the right problem before i go spend the money becsuse does sensers are to cheap..
Brett
SHOs before HOs
Minnesnowta
does a bad DIS always throw a code? just curious :)
