beboshopower
muy sho make a weir when startin it like if it ws the starter but is not...i unplug the ignition sensor an plug it bak an it did it could it be that....
me sry bt tis wuz hrd ta red....lol just givin u crap
Its makeing a weird noise? Is the noise when you turn the key on? or when you actually start it? It could be the DIS go to the junk yard get one cheap and try it, then go from there.
Codes? You might want to try and elaborate a bit more on what exactly the problem is. I'm sorry, but I can't make heads nor tails of what you said is wrong.
Moving to the proper section.
