DIS module blown
SHObill
'The Collector'
Rochester MI-48307Detroit
The ford mechanics blamed it on no dielectric grease, ....
Ha! I find that funny! Typical
-paste/grease has nothing to do with your problem! What IS IMPORTANT is the 2 lower DIS mounts to be clean & corrosion free to provide a proper GROUND! Along with the cross-over tube brkts & bolts & the flat black ground wire running off the rear right intake support brkt to the firewall. I think you may have wire issues from the first DIS being broken & the other PCM ground/battery ground wire you found.
I always add my own DIS ground wire right to the strut tower.
Mark_s
WA
Alright, that is important, I'm going to fix it right now, I think solder and heat shrink should do the trick!
Now, do you think this could have caused the problems? Oh, and thanks for the help!
Mark_s
WA
Alright, new symptom, I charged the battery today, and got it running. I re-learned the idle, and it was fine idling for about 10 minutes, and I occasionally revved it in between. Now out of nowhere, it starts to try to die, tach is bouncing between 0 and 1k, and if I give it gas, sometimes it will rev a bit higher, but still try to die, or it will cut out. It does this for a little bit, then goes back to being fine, and then does it again.
Now, when in drive/reverse, it doesn't do it at all, when driving, it does it the same when idling. Now, could this be a DIS problem, or something to do with the computer lead I patched? Or, could it be the Cam sensor like St. Louis SHO was saying?
CademiaX
What's an SHO?
Utah
are you those aftermarket DIS modules are any good? As many problems as I have had, none of them have blown the DIS, few for sale on here. Try that, don't ignore your check engine light.
Kens1992mtxSHO
The Commonwealth
It could be a DIS problem, ground problem, corroded battery cables, or cam sensor. I'm still inclined to say it's the DIS. I have a known good spare if you're interested.
I can't stress enough how important the grounding of the DIS is.
Mark_s
WA
Alright, I cleaned the IAB a little, and reset the computer, and after a little bit, idles how it should, the codes I got before were 411, 412, and 212, so I think that me giving the computer a better ground messed up its settings.
The battery cables look pretty good, I went over them with a wire brush to be sure though, but it didn't make a difference. Also, I think I'm alright on the DIS, it has more than enough dielectric, and I see absolutely no signs of corrosion, on the DIS or the screws, so I think it should be grounding fine. If this one blows, I will definitely hit you up for that spare though.
Oh, is there a way to check for a bad cam sensor? If that would cause it to run badly, then I doubt that would be it, it runs great, but could I check it with a multimeter or something?
93rev2sev
Hockeytown
pay special attention to the cam sensor section posted by gmorrel. It rules out the cam sensor as the problem.
It almost sounds like your problem could be a dying A/C compressor, boggin down the engine when it kicks on. If you think that might be a possibility, unplug the flat connector going to the front of the compressor, behind the belt. That will keep the A/C from coming on. If your problems vanish, bingo.
The A/C compressor will kick on if you have the EATC set to defrost/automatic (you don't need to turn on the A/C to run the compressor).
Mr Anonymous
Tire Wall
I agree that a diagnosis of multiple DIS module failures is suspect.
I would be more inclined to look at other ignition components, starting with the basics -- plugs and wires -- and then looking at the ignition coil and cam and crank sensors.
Because you found a stored code for coil #3, replacing the ignition coil with a known good one would be the first step that I would take and then look at plugs and wires.
Mark_s
WA
Big 'Ol Bump
Well, I finally got to drive the car for a while, and besides the terrible gas mileage, was fine, until the ignition module "Died" again, along with the glowing red cats. I figured I should go to the junk yard, and a module up, along with some other parts. The car was stripped of the I/M, so I took the alternator, as I didn't think it was charging right, and the coil at Mr. Anonymous's suggestion.
I installed both, and when I first started it up, it tried to die again, but after I let it charge for a while, it stopped trying to die, and runs great, but smells a bit rich. I took it for a 10 mile drive, and it did great, and had way better throttle response than before.
Now, if I did fix, or partially fix the problem, is there a reason why it is running so rich right now? Before the car died, I went 40 miles on 1/4 of a tank, but now it seems better, could the 02 sensors be clogged, and just need to clear up? Thanks for the help so far, I'm just sorry I haven't had a chance to use the advice until now.
:thankyou:
