Difference between engines
Warduke
New York
What if any are the differences between 91 engine and mtx tranny and a 94 engine and mtx tranny? and differnet prats on it or in it? different sized parts?
K-Dawg
Treasure Coast, FL
For the most part, they are the same. The 94 will have thicker cylinder walls, different intake manifold casting, different alternator and bracket, and a different wiring harness. The transmissions will be essentially the same; the only possible difference I can think of is synchro material.
jimtash
nc
Didn't the later V-6's have an EGR connection on the runner system or was it California cars only?
Phoenix
SHOHOLIC
QC , Canada
For the 'in it' as you asked , here's a couple diff notes you might need to know.
Diff front/rear knuckles and diff brakes.
Diff ECM but it's swappable.
Cable shifter vs rod shifter.
Mufflers are also a tad different.
