Did my ATX just go?
rlw001
Reading, PA, USA
On the way home my ATX shifted with a clunk and then I only had 1st gear and reverse. Did my tranny just blow? Is a 94-95' just a bolt in? Will a 94-95 the tranny work with my 93' axles? Which Trans-Go kit should I get? Anyone have a good ATX for sale in PA?
Ishodu
Sounds like it went boom, yes a 94-95 tranny will bolt in and will be a upgrade they are built better than the 93's. If you do this see if you can get the computer for the 94-95 as well. And it will work with the 93 axles.
SHO#7
Cincinnati
Scan first, and make sure that you vss is working. Otherwise... there is a good possibility that the transmission when SHOboom.
Good luck
Mike
rlw001
Reading, PA, USA
I did the KOEO tests and got 111-system pass, 172-lean RH, 177-lean-LH, 332-EGR, 543-Fuel pump secondary circuit failure, and 646-2nd gear failure.
I guess if my VSS was bad I would have got 452???
