Defrost mode door
beaudry
Canada
Does anybody have any tips for changing the defrost mode door? It’s the upper one on the driver’s side.
I’m driving myself crazy trying to get the last bolt out. I was able to get the lower bolt and one of the upper bolts(closest to steering wheel), but I’m about to give up on that last bolt. I can’t get a socket on it from either the space left by removing the instrument cluster or from underneath.
I’m following a service manual excerpt and one of the steps calls for the removal of the speed control deactivator switch. I can turn it the 45 degrees but can’t pull it off. So, I’m left with very little room to operate.
I don’t even want to think about putting the bolts back in.
I’ve been following the following instructions.
https://www.2carpros.com/questions/stuck-in-defrost-mode
xFallenxCripplex
I too have the same issue what tools are you using? I have only been able to get to the lower one
Sent from my Pixel 4 XL using Tapatalk
beaudry
Canada
Just been using a 1/4” ratchet, a swivel adapter and several extensions.
I had to remove the instrument cluster which provides a small amount of space to squeeze the socket thru. It was a tedious pain in the ass to remove.
And I had to give up twice on the last one. I’m gonna try once more this weekend before I put it all back together.
xFallenxCripplex
Yea I have everything just clipped back in for the moment till I got the tools or an idea how to do it wish there was a video on it
