javve
SHO Lovin' It
I got a Sachs clutch off of ebay over a year ago, put it in and ended up with the clutch not wanting to fully engage or disengage. It sat so long just because I didn't look forward to dropping the transmission again. I thought it was an issue with the throwout bearing, but it appears the pressure plate may be defective. The clutch disk was installed correctly, and verified when the tranny was dropped. One picture shows the splines all sitting flat. This happens when the bolts are hand tightened with a ratchet (using just one hand), and I had them torqued to factory specs (approx. 20 ft. pounds). The second picture shows what the splines do when the bolts are barely tight (the splines are out). The splines stick out like they are supposed to do. Do I need to replace the new pressure plate? Wish I had done things right away, would have been covered for a return.
Edit: I found out that the splines do flatten out. I think the problem may be with the way I was holding the throwout bearing in place. I was in a hurry because the car needed to get moved, and the bolt was too long not letting the throwout bearing go all the way back. :\
Splines Flat
Splines Out
Splines Flat
Splines Out
