stangrage
With a Rwd setup, has anyone ever modified the intake and welded two throttle bodies on both sides of the intake? If so what do you have to do about not throwing off the ECU?
Thanks
Thanks
Wasn't there a pic of a Merkur with a SHO motor and dual throttle bodies posted a while ago?
IMO megasquirt is the way to go.. i need to get it installed permently already but im back and forth with so many things lately.
i had the megasquirt up and running the car completely for fuel and ignition and it did excellent and not to mention was very easy once i got the issues worked out which was my fault...
i forgot to solder a jumper in when i built mine.
i often tossed the idea of something like this or even doing the secondaries and using the butterflies to do a ITB/ stock intake setup.
basicly take the secondaries and run ITBs right off the short runners.
i would imagine it would be good for probley 5 or more hp right off the bat if i were to guess
im not sure why it would need to be rwd?
Well It doesn't have to be rwd
