Cruchfield Recommendations for After Market Sub
shodazzl
Chicago, IL
I have a blown sub, and here is what was recommended.
JL Audio 8W1v2-4
or
MTX Thunder4500 T4508-04
How many watts is the stock sub amp? I am leaning towrds the MTX only because I think the stock amp may underpower the JL.
I will not upgrade the rest of the system, I am fine with spending just the 100 bucks for a woofer.
Thoughts?
spazmoid
RI
do alittle searching, i've seen it on here before, but i'm thinking about 35, but that could be the premium sound amp too
hawkeye18
Sorta cares
Norfolk, VA
I'm pretty sure it's 75WRMS. Now, keep in mind, this is for a 6 ohm sub. Multiply by about 1.4 for a 4 ohm sub, so 100-105WRMS. Why JBL went with a 6 ohm sub is beyond me, but there you have it. The stock amp is not very clean, though... especially after 13-17 years.
shodazzl
Chicago, IL
I thought the sub was 4 ohm?
SuperHO
Mental Patient
St. Joe, MI
The sub amp's puttin out 60wrms@6ohms IIRC.
You'd be better off with an old JL 6w0. Low power handling and drops right in. I've got one in a ported and baffled stock enclosure that sounds pretty damn good with the stock premium sound amp and using the Pioneer Head Unit crossovers for the rear channels...
jthod
Mr. Goodwrench
Lincoln, Nebraska
I recommend these from Crutchfield:
Picture158jpg212132
Sorry they won't fit in the stock box, but they are MTX's, :evilgrin:
tinkerkathleen
