Cranks but no start
Pablo sho
My 96 sho will not start this morning. Cranks over great but that's it. It's been running good but idle was surging a little yesterday. Sorry I have not hooked a code reader up yet or done much research. It's been a busy morning.
E1
Crash Tested
Chicago area
Cam position Sensor or Crank Position Sensor.
Also, 96's are cranky bitches. Try undoing the positive battery cable for a minute and reinstalling it, then try restart.
Pablo sho
No new codes just the 411 code that's always there. I will try unhooking battery and check fuses.
Pablo sho
I unhooked and rebooked battery. No change. Its unhooked for the night now. It sprays fuel out the fuel line but I dont have a pressure guage.
I'm surprised that no start has no codes. I agree the most likely is sensor failure. Could be a few things but that is where I would look. However, easy for me to say throw parts at something that I don't have to pay for.
E1
Crash Tested
Chicago area
Crank Position Sensor will not throw a code.
Have you tried cycling the key 3 or 4 times yet?
Turn the key to just before crank position, let pump run for a few seconds, turn off. Repeat a couple times, this builplds pressure in the fuel rail if fuel pump anti-backflow valve is faulty.
Pablo sho
I don't have much time to play with it but I did cycle the key several times. My truck tranny is malfunctioning now too. Back to driving the geo I guess..the has guage doesn't work right. I will probably ad some but there should be plenty. Only 175 miles on that tank. Maybe they didnt get it full. Hmmm.
gamefanatic
Barstow, CA
You may want to check for a stuck IAC. It won't necessarily provide a code, but if you push the gas just a bit and the car starts, that's an indication.
Pablo sho
I think the IAC was acting up. I held it to the floor and tried starting. I will try just a little throttle. Thank you
Pablo sho
Pablo sho
Pablo sho
Pablo sho
Sorry for multi post.
I tried throttle in many positions and still no fire.
SHOMON
95 MTX
MEDWAY MASS.
I wish I still had my Geo Prism to drive when the SHO needs work...
Pablo sho
I have a tracker. It's my grocery getter when the snow falls@
Pablo sho
No I wasnt. Remembered it working on a differant car so i tried it.
stephen newberg
Ladysmith, BC, Canada
I also think there is a very reasonable chance it is the IAC with those symptoms. Take it out, clean it very gently with rubbing alcohol and a cotton swab, and then try it again. Or just replace it. They are not hugely expensive.
pax, smn
Pablo sho
Thanks. I will have to research it. I might be able to do at least that much but I have had a out enough working on this thing.
