Cranking but not firing...
shodio
Orange County, CA
I bought my stock 1997 SHO with 178k miles and I have put 1,000 miles on it in the last two months with virtually no problems. However, I went to start it up yesterday and it would not Fire up. It cranks fine, just no ignition. The guy I bought it from included an igniter-Ignition module. Anyway, does anyone have a recommended procedure to track down the issue? I do not have a scanner. I am just above a novice repair guy, but I have people that could guide me if I get some specific direction from a v8 sho owner.
:help:
[email protected]
Ian Macoomb
Ottawa, Ontario, Canada
:help:
[email protected]
Sounds like a crankshaft or camshaft sensor has gone bad (or both). Or it could be a dead fuel pump. Check the fuel pump fuse under the hood. Mine had a problem where the wires chaffed and finally shorted out and blew the fuse.
Cams welded?
Crank sensor would cause this. You would need to back probe the PCM to see if you are getting an AC reading when cranking the motor over with a voltmeter at the crank sensor inputs. Pin 21 gray wire and 22 dark blue wire.
