cranking but no start most of the time. codes pulled
ohfosho
ontario SHOwner
ontario, canada
hey guys, i got my car back and pulled the codes.
212 IDM input to ECA, ignition tach signal erratic
214 CID problem (my no start problem?)
543 fuel pump open/circuit shows no power. or secondary circuit failed
632 tranny control switch not cycled. (i dont think the o/d button works, no light, but o/d is on)
i had more, but the battary has been dissconected a few times. but its been driven a bit since.
this is a 93 ATX, needs 60k with timing belt and waterpump too. (not done in last 100 kkm for sure), needs valve cover gasket (can the old one de reused/cleaned up, and some gasket maker added?)
so is this a crank or cam sensor problem? im hoping cam for now, because thats much easier to change. i am planning to do timing belt/wp soon, but need to drive for a bit!
wood_e
The dude
Ames, IA
crank sensor problem probably. If it needs a 60k go ahead and get it done.
shoteen95
isn't a teen :D
Dearborn Heights, MI
Even with a bad CID the car should be able to start eventually. The dead tach is a sure sign of a CPS problem as well. If your waterpump is leaking...fix that along with the CPS, or else you'll significantly shorten the life span of the new CPS.
ohfosho
ontario SHOwner
ontario, canada
i dont think that the water pump is leaking...but im not going to rule it out, because this isnt my daily driver yet.
With the 212 and the 214 I would look at a common problem such as bad ground to the DIS module or a loose connector to it.
shoteen95
isn't a teen :D
Good point, since i painted my intake, i've been struggling with a bad ground to the DIS. I've already relocated the ground strap and sanded the intake where it bolts to it, and have had pretty good luck lately. But sometimes my car doesnt want to start, and i know i have codes 212 and 214 stored in my computer.
I'm assuming it's a ground issue in my case, since before i removed my intake and painted it, it never had any ignition related issues
MJordan
greenfield, wi
My car had the same problem. It would crank but not start. The fuel pump didnt turn on though. Does yours? My problem turned out being in the relay box under the hood. So i had to have my fuel pump relay rewired. Its alot cheaper that way. The relay box is like $200.00
ohfosho
ontario SHOwner
ontario, canada
yup my pump is on. i can hear it...its pretty noisy. i think i will change that soon too. but it starts some of the time. but it has gotten much worse in the last 5 times that i have driven the car.
i am looking for some one to do the front 60 k in my area.
ohfosho
ontario SHOwner
ontario, canada
for the guys who have replaced both CID and CPS sonsors:
can you tell me what are the better brands/or which to stay away from (i dont wanna have to tear into the front again in under 20k)?
tinkerkathleen
