Crank pully
dan's 95 green SHO
some poor cold snowy Town
Is the crank pully suppose to be able to spin when car is in neutral, all the others do but not the crank I thought it was suppose to spin when car in neutral. Could pieces of old torn bely be stuck in the pully and stopping it???
Could that be why I shredded the belt in the first place??? Please help, I am confused and don't want to tear this belt too, then I can't get one untill after the weekend that would suck
Off Road SHO
Moderator
Hello Dan
The crank pulley is attached to the crank, which is attached to the pistons. If the engine is off, the crank pulley should not move at all. If it does, you've got big problems.
Tom
IAS92SHO
Michigan
The crank pulley, has a key way in it that prevents it from spinning on the crank. The crank pully, or harmonic balancer is what spins the rest of your pullys. Are you just replacing the belts?
