crank position sensor / tone ring
big b
barrington Il.
I've been rentless trying to find one of these.
I waited ten days to find out it is not the correct part.
The "ring" that (3) screws to the back of the lower timing belt pulley.
The three short flags pass through the crank position sensor.
I broke mine an need a new one asap.
Kean_SHO
Cleveland, OH
I think its called a pulse wheel. im sorry to say that i know this because i wrecked it when i didn't read the freakin manual.... specifically the part that says "gap the $*#@'ing sensor."
I think i got mine from Doug at FPS, but that was a couple years ago, so im not sure.
big b
barrington Il.
No, I did not have the CPS tightened down before I rotated the lower crank to check for clearance.
The tone ring wedged against the sensor and gouged the back side of the sensor.
Thankfully it did not come close to the pick up so I'm praying it still works.
did you forget to move the timing belt tensioner out of the way?
