SHOWYA
TurboSHO Member
Had to replace plug well seals. Replace at the same time MAP sensor and Knock sensor. After assembling engine back together it will not start. Fuel pump was becoming louder so i replaced with 190lph pump. Still nothing. Replaced relay because of no fuel pressure! STILL NO START, IT WILL ONLY CRANK. Went even to the extent to replace the CPS sensor. Checked for codes and all i get is a Code #10 and 111.
It has been a month and no luck. PLEASE HELP!!!
