Carraudio
My SHO won't start it has been brought to my attention that...
I found a crack in my DIS it is where the rear plug plugs into the DIS. Could this be the reason why my SHO won't start?
a bad ground on the intake manifold; check all connections including intake runner bolts and plenum bolts. A bad ground causes the DIS not to fully function and will not get proper readings to set timing etc, thus not letting the car start
