CPS - Thanks Forum Participants
93SHO_2
Omaha Nebraska
The problem with my SHO shutting down inetrmittantly has been corrected thanks to the input of the SHO forum participants.
The Crank Position Sensor (CPS) needed replacing. It was both dosed with oil from a leakey front crank seal and wet from a leaking water pump HOUSING (not the water pump).
NOTE: My Ford dealer says the 2 "O" rings and the inlet pipe gasket on the water pump HOUSING are no lonegr available from FORD, he found an extra set at another dealer which I will guard with my life.
The project: front oil seal, timing belt, pump HOUSING O rings and gasket, rebuilt pump ($60), crank position sensor, both accessory belts, about $325 for all the parts.
Tips:
1.) saw off a 5mm hex wrench so the tail is only about 2 inches long to have room while working on the PS/WP belt tensioner
2.) Helm book doesn't mention it but unbolt the power steering resivour so it can be moved to allow more room, and remove the vibration dampner bracket on the motor
3.) save the 2 longest front cover bolts to use to pull the timing belt gear
4.) use antisieze on the 6mm cover bolts, there ain't much to grab when they sieze, and the 3 piece covers are nop longer available from Ford
5.) when you change the clutch save the release bearing retainer sleve, it works great for tapping the front crank oil seal into place
fredhurderjr
www.neshospecialists.com
O-rings for the bypass tube are in the Upper Gasket Set, I believe. O-ring for the rear of the water pump housing are still available, I bought a packet of two last week for my engine swap.
pete c
ellington, ct
slosho,
drill to small holes in the front seal180 degrees apart from one another. screw short sheet metal or sheet rock screws into holes. Grab hold of screws wif channel locks or other pliers and pop dat bad boy out. Piece of cake. Don't pry it out like the idjit in the destructions tells ya to do. BTW, idjit, you did a good job otherwise. And I also noticed that things were a lot nicer with the power steering fluid tank outta the way.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
93SHO_2:
idjit???
It is no longer politically correct to call someone an idiot, even if they are. As you can see, we must improvise and use "code" words instead. Heh,heh, and you thought we only learned about SHOs on this forum!!!
Perry Toledo,Ohio
poffffd
