Cooling to well or is something broken?
trainguy1989
SHOtarted
Wichita, Ks
On my 94 ATX the temperature gauge only gets to the "N" or "O" (usually closer to the "N") on hot 90 degree days. I have even driven it 150 miles and it will not even get past the "O". I have read about the thermostat getting stuck open or the temp gauge sending unit going bad. I do not know what the most likely cause is. I have not driven the car enough to determine if fuel economy has suffered. Every time after popping the hood after running her for a while, she seems pretty damn hot, but the coolant has not reached the hot line on the reservoir (unless I need to add some coolant).
So, with all the experience you SHO owners have, which is a more likely cause?
Thanks,
David
trainguy1989
SHOtarted
Wichita, Ks
Well, I replaced the thermostat and the gauge still does the same thing. I guess this would have to be the temp sending unit, right?
CademiaX
What's an SHO?
Utah
I was about 109 here on Saturday. I drove about 200 miles and never went above the "M". I also have a triple core rad :p
1993MTXSHO
Its a Taurus...
Jersey
So you're gauge is within the "NORMAL" range, you have no diveability issues, are not getting poor a mileage and you made sure you're thermo was good. That gauge is very inaccurate, it works on resistance IIRC I really don't think you have anything to worry about.
If the car is running within the normal section on the gauge, that means it's normal.
