coolant tank
cjdavid
Cincinnati,OH
Has anyone changed their coolant tank? I talked to the guys at the e bay site that has replacements. I asked if they had one for the 99 SHO. they told me they had the one for a 3.0 but I want to know if it is the same as what we have or do I need to modify the one they sell. Also is anyone using a X cal2. I have spoken to Paul and am ready to upgrade the pcm. My car is a daily driver. The cams are welded, third cat is now gone and a KN filter will be installed at the same time of the flash, I am just looking for alittle more pressure to the trans,which has been rebuilt right before i bought it by a Ford transmission tech. Paul has recomended the X cal1, and I have no reason to doubt him, just wondering what the difference is with the X cal2
me6894
Canton, Ohio
i think theyre both the same, my mom has a 96 sable and my dad has a 99 taurus se and last time i looked they looked the same
midnightauto
THE CHOP SHOP
Michigan
A SHO has a low coolant sensor and the cheap $20-$25 aftermarket tanks for 3.0's do not. It will fit but you will have to bypass the sensor or look at the light until it burns out.
cjdavid
Cincinnati,OH
Yeah this is the issue for my SHO, the low coolant lite is on and want it to go off. So the one on e bay does not fix this lite on? Has anyone had any success cleaning off the sensor in the bottom of the tank. It must be the sludge making the contacts send the lite on me thinks?
nothingtoseehere
Um, I bought one from ebay, for the Duratec (same as the SHO for the tank) and it has the sensor in it
Not that I would doubt Paul, but for the money, get the Xcal2 from NESHO through Paul.
FoSHO99
FO SHO
Dubuque,IA
I have the same low coolant problem.....I just want the light to go off.....anybody know how to bypass the sensor without getting a new tank???
Its either that or electrical tape over the light....haha
Unplug the senor at the tank to eliminate the light.
I do not recommend a Xcal 1 over a Xcal 2 with regard to functionality. But the Xcal 1 can be had cheaper because it would be used.
After you pay for shipping you get to about the same price that AutoZone sells them for. If there's a problem, a local return is always easier. You can get the tank for the regular Taurus-- just get the one specified for the 24v car.
96blackSHO
Wrentham, MA
i had my low coolant light on
i just spend $75 and got a new tank from the dealer
went in in 10 min
and lights off
the sensors are known for going bad
The plastic is better suited and they are clear on the top. This allows you to better see the coolant flowing.
stephen newberg
Ladysmith, BC, Canada
That certainly sounds useful. Is there only one supplier on Ebay, or several, and if there are more than one, which one(s) are supplying the good ones?
Interested readers will want to know. :)
pax, smn
I got mine form the eBay store Tennessee Auto Sales. There is also 1A Auto.
Wess
Jarhead
MD
I got one of the fleabay ones and the sensor quit after about 4 1/2 months of use.
JCU
North Eastern PA
Shotime1979 said:
These are very cheap from the dealer.. I woulndt try to save $$ on ebay.
When my coolant tank developed a crack, the dealer was highly unreasonable for a replacement. If memory seves me correct, the price was in excess of $60.00. A trip to a local junkyard coupled with five minutes of my time and $10.00 later, I had an exact replacement from a 24V Taurus. The dealers are crooks plain and simple.
I know DANA supplies alot of the aftermarket ones. Looking at the failure rate of the oem unit I would not hesitate to try aftermarket.
stephen newberg
Yes, I find that interesting, since everyone tells me they go like mad, but I keep an eye on mine and it is the original and still doing fine. It stays pretty cool up here year round, compared to the lower US anyway. I wonder if that leads to a longer life expectancy before the tank gets cracks?
pax, smn
