Coolant Leak..
SHO Nick
******, Cali.
I have coolant leaking from a small little radiator or cooler..looks like a oil cooler or something...anyways its in front of the motor, and below...Its leaking coolant, does coolant run through this?
ALSO: Why in the hello...do I have so many coolant leaks and problems!? :rant: He sold it to me with no problems and Im getting all these problems now... :rant:
Bizzy
The SHO radiators have plastic end tanks and they are notorious for getting splits in them. They are cheap to buy and simple as pie to replace in the MTX cars. They also split out of the blue so it would really be hard for a previous owner to anticipate. I don't know who you bought it from so I can't vouch for him but it is highly unlikely that he knew there'd be problems.
SHO Nick
******, Cali.
No, I need help quick..lol, There is a small little radiator/cooler looking thing below my motor behind the standard radiator, its like 6x8 inches..and has two hoses going to it...it looks like im leaking coolant from there, but I would have no idea why coolant is running thru it..was is this small device? :squint:
Dr. Tweak
Mad Scientist
Northern Vermont
That's the power steering cooler, and it's not radiator fluid, it's ATF.
Just keep your power steering filled up until you can trim the lines back and install new clamps. :thumb:
Bizzy
Oh, ok that does sound like the power steering cooler. Kind of like a Master lock shaped deal with fins that is attached to the subframe. Best way I know to describe it.
I highly doubt it is leaking coolant. More than likely the upper radiator hose is dripping down and it's running off that or your radiator has sprung a leak and is spraying over on it.
Just to clarify, the liquid coming off it is green? If it's orange it could be el-cheapo tranny fluid used in the power steering, if it's red it's likely tranny fluid in the power steering. If it's clear it could be power steering fluid....however most of the time the rack will turn the nice clear fluid black fairly quickly. :)
If you're not sure what kind of fluid it is dab a little on your finger and smell it. We all know the sweet smell of coolant.
SHO Nick
******, Cali.
Its definantly green...smells and taste like it too..I had suspecion it was running down the cooler lines..and then running off the cooler itself..might be somwhere else.
SHOman24v
Fresno
Nick, id check your radiator cap you put on, i noticed that you changed it...it really didnt need to be changed, id put the old one back on and see if that fixes the problem.....
I think that may be your problem
SHO Nick
******, Cali.
Hmm..it might..but its leaking totally opposite of the cap side..all I did is put that pressure release on one...hmm...
SHOman24v
Fresno
id try the one i had on it.... check the drain plug on the lower part of the rad by the ps cooler, its a white plug make sure its tight... :thumb:
SHOman24v
Fresno
Ive been thinking, were you say its leaking i believe that that is a drain hole if the pressure is to great (anyone correct me if i am wrong).... i the hole where you screw in the drain plug, you will see it, it points down... id recommend trying the orignal cap
that also may be the reason why the heater core took a ****
