DemonNeno
SHOCAGO Freak
Anyone attempt something of this nature? I'm in need of axles, looking at '94+ spindles, and want ABS for a rear brake upgrade (13" on the front with 10.2 in the back just seem... unworthy
). Other than the 4 ABS sensors, wiring, and the ABS control module, axles what else must be changed? What would be required for the rear spindles? Hubs w/ rings? Not quite sure how the ABS works out back.
TIA!
EDIT: Forgot to add the ABS res. tank. Would the non-ABS master work or would a ABS equipped version be required?
). Other than the 4 ABS sensors, wiring, and the ABS control module, axles what else must be changed? What would be required for the rear spindles? Hubs w/ rings? Not quite sure how the ABS works out back. TIA!
